Results 1 to 10 of 25
Thread: used yellow out before I found you.....
    Default Re: used yellow out before I found you.....
    Quote Originally Posted by hkcon View Post
    (I am using "guys" in the non gender specific sense)
    Yep. You're from San Francisco (to feel like it's necessary to add that).
    Just buy plain stabilizer -- cyanuric acid. It dissolves slowly, but works fine, and is more concentrated than the liquid stuff.
    Clean your filter -- so you can run several days without backwashing or cleaning, and add your stabilizer SLOWLY to the skimmer with the pump on, the skimmer circulating, and the skimmer basket in place. Run your pump 24/7 for the next 3 days.
    Meanwhile, keep bleaching at night, till you hold a chlorine level during the day.
    Ben
    I'd start with 7-1/2 lbs of the granular stabilizer which should take you to about 35ppm of CYA. Add it slowly so you don't clog the skimmer pipes. Don't test for it for about a week before deciding whether or not you need to add more. It is always easy to add more later than it is to get rid of it when you have too much.
    Jun 2011
    San Francisco (East Bay area)
    you "people" LOL are the best..
    Jun 2011
    yes the pool is clear and bright and hopefully now with the stabilizer in we will be able to keep chlorine around for a min.
    Jun 2011
    so if I am reading the chart right...at 35 ppm of cya i want 3 to 6 ppm of chlorine, and with my pool size of 26,000 gals. then i get about 4 ppm raise from a gallon of 10% chlorine?
    You are right on both accounts!
    Jun 2011
    Ok, First off let me say thet this site and Pool Doc and Water Mom and CarlD you are the best , the absolute best. I did exactly what you all said to do and Bingo....my pool is CRYSTAL CLEAR, the water feels great...and best of all I have held my chlorine level for 2 days now!!!!!!!!!!!!! THANK YOU THANK YOU THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
