Re: 3" pucks
If your pH keeps going to low then you shouldn't be using trichlor in any form. It's very acid and drives pH down faster. If you had a problem with RISING pH (common in new and resurfaced concrete/plaster pools and some SWCG systems) then it might be a good thing.
Bleach/liquid chlorine won't affect pH and Cal-Hypo is somewhat alkaline, pushing pH up.
