Results 1 to 10 of 65
Thread: How long should it take to clear black algae
    Yeggim is offline Registered+ Thread Analyst Yeggim 0
    Aug 2010
    Philly
    Default Re: How long should it take to clear black algea
    Quote Originally Posted by joecus View Post
    Today, is sunny and I'm back to adding tons of bleach. My test kit is the Taylor one recommended here. I do want to switch to a higher bleach content. Is there any online store you use to order 10 or 12%? Also, please explain how much of the 32oz would = 128oz of the 5.5. It sounds like two quarts = 1 gallon but not sure. As far as the inconvenience 0f gallons, it's not a big deal. It's actually funny the comments I get from the cashier when they see me buying all their bleach. I pay $1.47 per gallon. How does compare to your price?
    Shipping costs would negate any savings over your current price, which is actually very good if it's 6%. A 5 gallon container of 12.5% weighs 40+ pounds. Is your bleach marked 5.5%? Even at 5.5%, a $1.47 a gallon is good. Are you sure it's a gallon? I don't see gallon jugs around here anymore. They're either 96 oz jugs or the 182 oz jugs.
    joecus is offline Lifetime Member Thread Analyst joecus 0
    Jun 2010
    nyc
    Yes it is 1 gallon. It's a store brand (pathmark). It does not give the % on the label. I've tried to look up the % on the web without any luck. The directions match Clorox so I'm assuming it's 5.5. I've just ordered an ammonia test kit to see it that's my problem. Just a long shot chance. Last year I did have a major issue with one of the algaecide. The product name was United Chemicals Black Treat 3. It was a very weird problem, after adding this product, whenever I added chlorine, it would turn the water light green. By morning it was back to crystal clear. The water tested positive for metal. I bought a magnet/powder from my local pool store and mixed it with the earth. I did this along with few partial refills and the problem went a way. I'm thinking this may be some sort of residual from that problem. Any thoughts on partial doing partial refills. I have not been able to confirm the algae (smear test) due to me scrubbing it away on Saturday. I cannot see an algae present right now. One thing I have not been doing is running the filter 24/7. I reread the article Watermom put up and they suggested running 24.7 I am going to start doing this today.
    Jun 2010
    nyc
    I have a new development. I can't believe what going on. As I told you, my kit ran out of r0013. My last reading, two weeks ago, was 70. Last week I was using the strips and it dropped to normal on the strips 30-50. Today, I used the strip and it's showing zero. Now, I really need help. Please let me know what you think. Thanks very much.
    Aug 2010
    Philly
    Stick with the reading you got with the R0013 reagent with the black dot tube. Did you order more R0013 reagent?
    Jun 2010
    nyc
    Yes I did, today. I also went to Petsmart and bought an ammonia kit, pool measured zero. Here are my latest numbers.
    CL = 9
    PH = 7.2
    I'm going to test first thing in morning. I will re-post then.
    Jun 2010
    nyc
    Yeggim - The water is crystal clear. I have very good news. My CL levels held very steady over night. Last night, CL=9. This morning it looks like 8 or 9. I feel much better than yesterday with regards to the pool. I was very worried the pool had an ammonia problem. As I said, that test came back negative. My CYA - is unknown due to the fact that I ran out of r0013. The strips have been showing a wide range so I'm sticking with my last "known" CYA of 70. So what is my target now with regards to the CL levels? Thank you for your help. One more thing, I would like to make a donation to the site. How can I do this?
    Thank you, Yeggim for supplying the needed links for this member.
    Joecus --- thank you for your interest in making a donation to the Forum. It will be most appreciated!
    Glad to hear of the overnight results. That is good news!
