Re: High Phosphates > 1,000 & High Nitrates 90ppm
Actually some good questions:
"Shock" level is to kill the algae in your pool. That's the 20ppm you need--or higher.
But "Maintenance" level is what you need to KEEP your water sanitary. With a working SWCG, the level of chlorine should be NO LOWER than 5% of your CYA level. So if your CYA is 60, you need to keep at least 3ppm of chlorine for maintenance.
Here's a silly analogy: Say you have flying bugs in your house. You need to "bomb" the house to get rid of them. But once they are gone all you need to do is make sure your screens are well-fitted and not left open.
Borates is a whole different story. I wouldn't worry about them for now. Later, when you are comfortable with the basics, you can look into that. Some don't bother with borates (like me). Others do. There's no "right" answer just choices. You are OK without them for now.
The pool calculator works great but you can estimate too.
1 gallon of 6% bleach add 6ppm of free chlorine to 10,000 gallons of water. So, for your 26000 gallons (and it's probably really 25K) you need to use 2.5 gallons of 6% chlorine to get the same 6ppm. 5 gallons gets you to 12ppm. 10 gallons gets you to 24ppm (That's why I like Liquid Chlorine at 12.5%--you get the same effect from 5 gallons of LC 12.5% as you do from 10 gallons of 6% bleach.)
