Is your CYA reading posted somewhere in there and I just missed it?
it shouldn't be the DE causing the cloudy water. If it is, then you have a problem with your filter. Did you notice the DE coming through the return jets as you poured it into the skimmer?
How long was your chlorine zero? It could be that you just have an algae bloom in the works. It doesn't take long for a pool with no chlorine to start growing stuff.
