Glad the pool is clear and it appears that the DE filter was not the problem. Good. Do yourself a favor and order that good test kit. You won't be sorry you did. It will do everything you need a kit to do and it will make your pool maintenance much easier as well as make it a lot easier to clean up if you ever have a problem. Good luck.
