Re: Going. Insane. Need help, please
OK, thank you in advance for your help.
This is for a vinyl pool.
When we initially started work on getting the pool up and going we had the water tested at the local pool store. The levels were extremely low and had to add a few different chemicals. This was about a month or so ago.
Initially we added 4 chlorine tabs to the skimmer basket. We then added 33lbs of Alkalinity Up and 27lbs of Hardness Plus spaced 24 hours apart. In between that 5lbs of shock was added.
Some more removal of leaves took place as well as some backwashing in which plenty of filthy water was pumped out. Slowly we started to see a difference and the water started to change color from a murky green, almost black to a light green.
More shock was added and more backwashing ensued. We had about a week of torrential rain which set us back and more shock and chlorine was added to fight the algae. We also added a quart of algaecide to the pool.
Eventually the water cleared and just lately when I have been vacuuming up minor debris that has blown in, that has process has been fine, although when vacuuming via waste the water has been clear and not murky like when we first started.
We last added another quart of algaecide and 2lbs of shock at the beginning of the week.
I have a drop based kit which I will use in the morning and then post the results here. I'll also attempt another round of vacuuming too.
