Re: Pool is clear finally, Now the liner is stained.
Socks catch particles in the water that might otherwise pass through the filtration system. If it is still not clear, I'd keep the cl high for a few more days. You've come too far to quit too soon and have to start over. Also, you should be running the pump 24/7 while you are trying to clear the water. Have you testing in the evening after the sun is off the pool and again in the morning within 2 hours of sunup to see if you are losing more than 1ppm of chlorine overnight. if you do lose more than that, it is a sign that you are still fighting something in the water and should continue high cl levels.
