Results 1 to 10 of 18
Thread: liner change - new water
    drband's Avatar
    drband is offline Lifetime Member Thread Analyst drband 0
    Gainesville, GA
    Default Re: liner change - new water
    You can drizzle bleach in as you are filling. Just reach as far from the side of the pool as you can, being careful not to splash your liner or yourself. Take a clean broom or oar or something to stir the water up to mix in the bleach.
    Good to see you back on the forum this year!
    OK, will add some bleach as we begin filling. I'll wait on the other 'til the water level reaches the skimmer and then add based on testing. Hope this will keep algae out! I haven't had algae for 5-6 years and my goal is to start up with the new water/liner algae-free.
    thanks Carl and WM.
    You're welcome! Remember, until you get some CYA in there, the chorine is going to disappear fast! You'll have to add bleach several times a day for the first week of so. A pain in the patootie ---yes! But, better than an algae bloom!
    Keep us posted!
    drband's Avatar
    Gainesville, GA
    pool was drained tonite. should have the liner switch tomorrow if weather cooperates... some nasty thunderstorms around here lately! If all goes well, we'll begin filling the pool tomorrow afternoon sometime. Will try and post photos!
    Apr 2011
    virginia
    Good Luck!
    drband's Avatar
    Gainesville, GA
    drband's Avatar
    Gainesville, GA
    Looks like the new liner will have no wrinkles (unlike the old one) and the color is brilliant compared to the old faded liner. The process looks easy but awkward to handle. I'm glad I paid an installer to do this (this time). Next time, I might give it a try (hopefully many years from now)!
    Added a cup of clorox last night and stirred it around. Will add a bit more this morning when the sun hits. Installer will come by to put the face-plates on today and then I can fill it up and get the water balanced.
    Note: Instead of using shopvacs to suction the air out under the liner, the installer used a high speed fan like the kind used to dry out a flooded basement. They put the air intake over the skimmer basket cleanout opening and some kind of tube (cardboard?) under the liner wall from the skimmer wall opening down to the bottom of the wall. Looks like he can just pull the tube out, reattach the liner at the top and put on the skimmer face plate and he's done! This looks like it works much better than using vacs. The liner is so tight to the walls, it looks like it was sprayed on! No wrinkles at all.
    Your pool looks great! Thanks for sharing pics. Also, thanks for the info about how your installer did the liner. That is what makes this forum great -- lots of pool owners sharing!
    May 2011
    kentucky
    that is exact liner pattern i used in my change this year it look great when water is full congrats!
    drband's Avatar
    Gainesville, GA
    My liner installer says that this pattern is used in 75-80% of his installs. It IS striking when the pool is full.
    10,000 gallon IG vinyl liner pool, BBB user, salt added to 2300 ppm (because it makes the water feel great!), new liner/new water on 6/23/11, algae-free since 2006 (at least that's as far back as I remember). 1HP Hayward 2-SPEED CONVERTED Superpump, Hayward sand filter, PS234 test kit.
    Goal: To remain completely algae-free for the life of this new liner!
    Life lesson: It is what it is.
    12'x24' oval 9K gal IG pool; bleach; Hayward 244T sand filter; Hayward Super pump, 1 HP, 2-speed pump; 24hrs on low speedhrs; PS234; utility water; summer: ; winter: ; android phone; PF:13
