Results 1 to 10 of 39
Thread: kjh9835's pool
    Jun 2011
    Southern Indiana
    Default Re: kjh9835's pool
    I'm back with baking soda, bleach, borax and a 6 way drop test kit.
    FC >5 (shows up deep yellow)
    pH 7.2
    TA/CA 300
    CYA 40
    I added stabilizer this morning. There is residue on the bottom of the pool so I'm off to vacuum it again then if it needs more in the morning, I'll put it thru the skimmer.
    Thank you again,
    kjh9835
    I don't know what happened to your post that I moved this morning. That was weird. We've asked Ben to figure out why you couldn't see it.
    At any rate, I hope you didn't add much stabilizer since you are now reporting that it is 40. That is a great level and you really don't want it higher. How did you add it? If you added it to the skimmer, can you rinse the cartridge to remove it? Or, did you broadcast it across the pool? If so, vac to waste to remove it. You really don't want it higher than 40-50. With a CYA of 40, you'll want to shock the pool up to 15ppm and try and keep it there by frequent testing and adding more bleach any time you find that it has dropped. There is no such thing as adding bleach too often when you are trying to clear a pool. I estimate your volume to be around 7000 gallons. In a pool this size, each quart of 6% bleach will add about 2ppm of chlorine. You can use that as a reference to help you figure out how much bleach to add each time you test to get back to 15ppm.
    Run the pump 24/7 right now.
    EDIT -- I wanted to thank you for becoming a subscriber. We appreciate that as it helps the forum online.
    Jun 2011
    Southern Indiana
    Again, I apologize if these end up being duplicate posts. I have lousy internet service and don't know when they appear unless I log out and come back. If they aren't there, I repost.
    I broadcast the stabilizer this morning but have cleaned the bottom twice since then so most of it is gone. Glad to have the bleach ratio info, I wrote that down in my logbook for future reference.
    Your welcome on the subscriber, I'll gladly support anyone/anysite that provides helpful information esp when it comes to things I know very little about and saving money. I can return the un-used chemicals, get more than that back not to mention what I won't be spending in the weeks to come. I told my sister about your site also (she has the same pool in TN).
    There's no way to hang a sock directly over my return spout but I can make a sheer fabric bag tomorrow with hanging loops to go around the top edge of the pool and still be long enough to reach the return spout the correct distance for dispensing chemicals. If the chemicals damage the bag, I'll just make another. I made my own larger size debris bag for the vacuum since ours disappeared. Knee highs work but they stretch out too much. I had planned to make an XL size leaf/debris skimmer with a hula hoop and sheer fabric but bought a surface skimmer that hangs on the side instead for $25. Other than the $14 here, it's the best thing I've spent money on for the pool.
    Good night,
    kjh9835
    Since you are reporting that your CYA is 40, don't add any more CYA. Do not do the hang a sock in front of the return thing. Your CYA is already high enough. When you removed the CYA from the pool floor, I assume that you vacuumed it up which means it is now sitting in your filter dissolving and adding more CYA which you don't want. So, backwash your filter and get it out of there.
    One other note --- remember that new members have to have their posts approved by a moderator before they appear on the forum. When you post, your post goes to a moderation queue to wait until one of the Pool Forum staff reads it and releases it from the queue. So, you will not see your posts immediately upon submitting them. Usually one of us in online most of the time, but sometimes there may be a couple of hours when none of us are. But, typically your post will be modded in within a couple of hours if not sooner.
    Jun 2011
    Southern Indiana
    Had already gone to bed when you replied. I did wash the filter out after cleaning the bottom and after testing this morning and reading your post, I put a new one in since these were my readings:
    FC orange (test only goes to 5 so I figure it's plenty shocked)
    pH 7.5
    TA/CA 250
    CYA 60 (so new filter to keep more out).
    Since my bottle of CYA solution is only good for three tests (22 ml bottle, takes 7ml each test), I'm assuming I can purchase single bottles of solutions? Nearest pool store is quite a drive for me and I go back to work today so online is my best option. Who uses what company for the best prices/shipping options?
    Once I get home tonight, should I start on the lowering the TA level with the step by step method I printed off yesterday?
    I understand about the post approval before appearing, I usually won't look right away as it takes time for other members to read/reply anyway. I just have trouble with my internet and didn't want to aggarvate anyone by having two or three single posts of mine show up and have to be removed. I usually have to post, copy that post, submit, log off, log back on, refresh then paste my post in again before it will even give me the message "waiting on approval". It's not your site, but any forum I visit. I just deal with it but sometimes I do have duplicates show up.
    Have a great day and thanks again for your replies/assistance.
    kjh9835
    How does your water look today? Yes, you can go ahead and start working to lower the alk. It is a gradual process so don't expect huge changes quickly.
    I'll let someone else advise you where to buy CYA reagents but to answer your question, yes, you can buy bottles of it. In fact, you can buy much larger bottles of it than what comes in the kit.
    While you are doing the online ordering of the CYA reagent, do yourself a big favor and go ahead and order a good test kit. We recommend the Taylor K-2006 or 2006C which is the same kit with larger bottles of some of the most used reagents. If you order through the Amazon link in my signature, the Pool Forum makes a little money on the sale which helps keep the forum up and running. Only buy if the seller is Amato Industries, however. Some other sellers are substituting the K-2005 which you do NOT want.
    Regarding making duplicate posts -- don't worry about it if it does happen. One of us will just delete the extra one. Glad you found us and hope we are helping! You have a great day, too.
    I believe you can also order reagent refills from Amato Industries, but you can also get them directly frrom the Taylor site (taylortechnologies.com). I usually get mine from www.spspoolspas.com, since they have one of the best prices I've found. You might look at the instructions that came with your 5-way kit and see if there's a phone number there to reorder reagents, and compare their prices.
    I would wait to start lowering your alk until the pool shocking is done, because the amount of acid you use at a time to lower the pH and alk depends on an accurate pH result, which you won't have when your chlorine level is above 10 ppm. With chlorine levels above 10 ppm, pH results tend to read falsely high, so you might end up accidentally lowering your pH by too much by depending on a false high number. Get your chlorine issues adjusted first, and then when you can let the chlorine drift back down to "normal" ranges, then start working on the TA.
