Jandy valve ... water getting past closed valve
Not sure how to fix... I have a pool / hot tub combination. Recently I've noticed my hot tub water levels dropping when in the "hot tub' mode ... closed system recirculating water between pump, heater and hot tub. At first I thought i had a leak. After many checks and no leak found I noticed that my pool cleaner still had a very small amount of water seeping through to the pool (via a jandy never lube valve). After capping the pool inlets and cleaner inlet I discovered that the hot tub maintained water levels. I think my jandy valves are allowing water to pass through them in the closed position. Not sure what the repair might be. Any help is appreciated.
Fiberglass IG with hot tub/18,500 gallons
