Thread: Salt water conversion(above ground pool)
    Jun 2011
    Midlothian, Va
    Question Salt water conversion(above ground pool)
    Hello all,
    I have heard nothing but good things about salt water systems for pools, but the only application I have heard of is in-ground pools. So I was wondering if it is possible to use those systems in above ground pools and is it recommended? If it is, can I buy and install it myself or should I have a pool company install it?
    The pool I have is a 26' above ground pool. I am not sure what other information you would need.
    Thank you,
    lndknox
    Default Re: Salt water conversion(above ground pool)
    Larger AG pools tend to have more exposed metal than IG pools. Salt water drying on that metal can definitely accelerate corrosion. How much of a problem will that be? I don't actually know.
    Ben
    Jun 2011
    Midlothian, Va
    Thank you for the quick reply. The whole top of my pool has a metal rim, but I think its made out of aluminum. Very good point and I will have to look into what is exposed and has the possibility to corrode.
    Jun 2011
    Ringgold, GA
    I'm a total noob here, but researched the same thing. Supposedly, this voids many mfr warranties for the reason Ben points out. May want to consider that as well.
    Jun 2011
    Midlothian, Va
    New here also, but thank you for the additional information.
  1. New user considering salt conversion
    By FrederickG in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-09-2012, 03:08 PM
  2. Salt water pool conversion.
    By UVindex10plus in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 12-29-2011, 02:41 PM
  3. Salt Water Pool Conversion
    By jskins2000 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-08-2011, 07:42 PM
  4. Above Ground Salt Water
    By BeanoB in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-25-2011, 05:55 PM
  5. Need Advice on Salt Water Generator purchase & conversion
    By mickey4paws in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 03-22-2009, 08:31 PM
