intek salt water back to chlorine
I have a 16x48 intex pool and recently bought a salt water pump. I put 100 lbs of salt in and followed all directions. When salt water pump was turned on I kept getting a low flow alarm. Nothing I did would help the flow. I decided to return the pump; however, the salt is still in the pool. Can I go back to using chlorine and other chemicals with the salt in the pool or do I need to drain it and start all over again?
Thanks!
