Run your filter....the chlorine will kill algae in the water, but it's the filter that will remove it. Keep the filter running, keep adequate levels of chlorine in the pool (3-6 ppm with your stabilizer level) and you should be fine. Once the filter gets all the dead algae out of the pool, you should see it clear up.
