Absolutely!! If it didn't turn pink, that means you have no CC, and that's the whole goal!! Your other numbers look pretty good, other than the CYA still being too low. A feed store probably will not have CYA, but if you have a Tractor Supply Co (the chain) nearby, sometimes they do. Otherwise, go to WalMart and check the section where the spa chems are.
