Results 1 to 10 of 36
Thread: Taking control of my pool this year
    jilted is offline Registered+ Thread Analyst jilted 0
    Jun 2011
    Louisiana
    Default Re: Taking control of my pool this year
    Just checking in. My pool has been doing great. I've been checking the FC and pH pretty often and my last CYA check was around 50ppm. My FC has been running around 3ppm. I'm still running the unit at 20% output and the pump runs for 9 hours. I ordered a salt test strip kit so I can validate if the reading on the SWCG is accurate. Going to give it a shot this evening.
    I still have to make a decision on a vac though... my polaris works one day and not the next or works for an hour then moves slow for a while then moves fast again.
    26,500g inground vinyl liner (new liner installed June 2013)
    Hayward 1.5 HP Super Pump - Hayward sand filter (sand changed in spring 2009)
    Compu Pool CPSC36 SWCG - Polaris 380 cleaner
    Jun 2011
    Louisiana
    Looks like running at 20% for 9 hours is pretty much a slow downward slope.
    I thought of something else that I didn't cover regarding shocking the pool. Is there a preemptive schedule I should follow? How many PPM rise should I shoot for when shocking? I should be using liquid bleach for this right?
    Thanks!
    -stephen
    You shock whenever you have cloudy or green water, a CC reading greater than 0.5ppm or if you lose more than 1ppm of chlorine overnight. Shock levels are based on CYA levels. Take a look at the Best Guess Chlorine chart in my signature. Yes to using liquid chlorine for shocking purposes.
