Page 5 of 9 FirstFirst ... 3 4 5 6 7 ... LastLast
Results 41 to 50 of 84
Thread: Time to replace sand?
  1. #41
    jonno is offline Subscriber Thread Analyst jonno 0
    Jun 2011
    Brookeville, MD
    Default Re: Time to replace sand?
    Evening numbers;
    FC 9.5
    CC 1.5
    pH 7.1
    TA 170
    Dosed another 9 gallons. Visibility is better - I can actually see the return port.
    Taylor K-2006, IG Vinyl 26,000g, Sand filter 275 lbs, 3/4 HP Hayward Super Pump II, CYA over 100, Using 12.5% bleach
    18'x36' rectangle 26K gal IG pool; Liquid Chlorine 12.5% ; Sand Filter 275 lbs. sand filter; Hayward Super Pump II 3/4 HP pump; 23 hrshrs; Taylor K-2006; delivered via truck; summer: ; winter: ; iPad; PF:4.6
  2. #42
    Jun 2011
    Brookeville, MD
    Morning numbers
    FC 25.0
    CC 2.5
    pH 7.2
    TA 190? weird colors again (FC so high?) Trace amounts of foam (less than past days), visibility seems to be improving, and green coloration is lighter.
  3. #43
    Jun 2011
    Brookeville, MD
    Although the FC numbers are looking good and the water is improving, the TA is staying in high (170 to 190) despite constant aeration and regular doses of muriatic acid.
    • Should I continue with the acid to keep it to 7.0 even if it means adding muriatic acid every day or two?
    • Is there any risk of the pH or TA test colors being off because of the high FC?
    Thanks,
    John
  4. #44
    Jun 2011
    Brookeville, MD
    Bottom comes into view!! First time this season I could see my brush making swaths across the bottom as it stirred up the algae - I could see all of the shallow end and halfway into the deep end. What a huge difference in 12 hours! This is so encouraging after weeks of POPP. Evenings #s are:
    FC 13.5
    CC 2.0
    pH 7.1
    TA 190
    Can any of the experts answer my questions in the last post?
  5. #45
    Quote Originally Posted by jonno View Post
    [*]Should I continue with the acid to keep it to 7.0 even if it means adding muriatic acid every day or two? [*]Is there any risk of the pH or TA test colors being off because of the high FC?
    The pH may register falsesly high when your chlorine is above 10 ppm. The higher chlorine should not affect the TA test colors. The ratcheting down of TA can be a very lengthy process, and it is slower in your pool because your pH is staying low before each acid addition, so you're not able to drop the alk very much with each addition. If you had some form of aeration in the pool (fountain, etc), the pH might rise a little higher each time, allowing you to make more progress with each acid addition.. I would continue to work on it, using the method that you're using, until you at least get it down to the 140 range.
    My pool is maintained with 80-90 ppm of CYA, and I use approximately 4-5 of the large jugs of WalMart bleach weekly to maintain 8 ppm in my (roughly 29K gallon) pool, to answer one of your earlier questions. (I've been working nights this week and somehow missed a whole page of your thread..sorry!)
    Glad to see you're seeing progress on your pool. Hang in there--it will all be worthwhile in the end!!
  6. #46
    Jun 2011
    Brookeville, MD
    Thanks Janet. The water is getting better. It is still very cloudy, but that is an improvement over the opaque murkiness of the past month. I still can't see the bottom of the deeper areas, but I could make out a dark clump of leaves about 5 feet down that I then scooped up.
    This evening the FC is 17.0 and CC is 1.5. I know though that it is far from the goal of losing 1 ppm of FC per day and 0.0 CC.
    I'm still following Ben's prescription to dose 9 gallons of bleach a night. When I put in 9 gallons of 6% bleach tonight, it added 21 ppm of FC to the current level of 17.0 for a total FC of almost 38 ppm. Is that level okay? FYI: My CYA is somewhere over 100 (the black dot disappears very quickly, far before the 100 mark).
    • Question: Should I be altering my dosage to target a nightly FC level or continue with the 9 gallons/night dosage?
    My pH color is hard to match but there's a hint of purple that may line up with 7.4. But, you pointed out that pH colors can appear falsely high when FC is over 10 ppm. I'm going to hold off on adding any more muriatic acid pending expert advice.
    The TA is 170. I found another aerator and will hook it up tonight to add to the ripple from pointing the return upward.
    Thanks for guiding me through this ordeal.
    John
  7. #47
    I think I would see what my cl reading was before adding bleach and then make a decision. Taking cl up to 38 is pretty high for a vinyl pool. I would probably not take it any higher than 25ppm.
    Keep working on lowering TA. If you don't work over the weekend, see if you can test as many times per day as you can and each time, take the cl back up to 25ppm. Every hour or two or three would be great. No such thing as testing and dosing too often when you are trying to clear a pool. If you can do this for the next two days, maybe you can turn the corner.
    EDIT -- Since you have the Taylor K-2006 kit, your pH test will be accurate if the cl level is lower than 15 instead of 10 like some other kits. So, check your pH as soon as your cl drops below 15ppm.
  8. #48
    Jun 2011
    Brookeville, MD
    Thanks Watermom. This mornings FC was 23.5 so I added 0.3 gal of 12.5% bleach, at 6.8 ppm per gal, this should raise the FC by 1.5 to hit the 25 mark. I'll do this every hour or so throughout the day and see if I can get someone to do it more frequently tomorrow (a work day for me).
    I'm off to the pool store now. I never thought I'd darken their threshold, but I'm almost out of R-0871 and my re-order from Amazon is not due until the end of the week.
    If in any of the FC tests today is 15 ppm or below, I'll test pH - otherwise I'll check it in the morning and add muriatic acid if it is above 7.0. The water is definately blue again. It's still cloudy but less so than yesterday.
  9. #49
    I'm keeping my fingers crossed that two consecutive days of non-stop babysitting this pool will make a difference. Keep us posted!
  10. #50
    Jun 2011
    Brookeville, MD
    Just returned from a 2 hour quest for R0871 FAS-DPD Titrating Reagent. Leslie's told me over the phone that they had it in stock, but they had only the DPD Reagent #2 (item # 81345). The item I need is in their online catalog, #81348, but not on the shelves. Tried 3 other pool stores - no luck.
    I ordered 2oz of R-0871 from Amazon last Wed, but it won't arrive until Thursday. I had to resort to Carl's shot glass method and mixed 1 part pool water to 4 parts distilled water then used my pre-Taylor K2006 test kit to test for total chlorine and multiply the results by 5. Since the highest readings I can get with my old kit maxes out at 5 ppm, the best I can do is get a vague sense of whether I'm dipping below 25 ppm (since 5 x 5 = 25).
    When I did the test it appeared to match the color for 3. Multiplying by 5 gives a result of 18ppm - but it is a guess at best. Based on that I was conservative and added 1/2 a gallon of 12.5% bleach - waited 30 minutes then retested - it seems to have pushed it up from the 3-ish level to the 5-ish level (x 5 = 25ppm).
    I'll try it again in a few hours and adjust accordingly. Every pool store I visited said the max chlorine level they can test is 5 ppm. If anyone knows of way I can do this more accurately before my Amazon shipment arrives - please let me know. What a bad time to run out of reagent!!
    John
  1. Time to replace the cell?
    By semenzato in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-24-2011, 03:26 AM
  2. How often shoud I replace sand in sand filter?
    By mikef in forum Pool Equipment & Operations
    Last Post: 07-18-2011, 11:41 PM
  3. Time to replace the QuikChlor...
    By steveinaz in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-20-2011, 11:44 AM
  4. Time to replace my liner?
    By mdenegre in forum In-Ground Pool Construction and Repair
    Last Post: 11-14-2010, 10:39 AM
  5. Time to replace the Dolphin Dynamic
    By beantown in forum Pool Cleaning: Manual or Automatic
    Last Post: 09-09-2010, 09:28 PM
