Results 1 to 10 of 17
Thread: need to cover my pool for 6 weeks while i am away...help with chemical suggestions
    Aug 2010
    Default need to cover my pool for 6 weeks while i am away...help with chemical suggestions
    I will be leaving for 6 weeks and need to cover my pool. I live in NY and so it will be covered in the hight of summer. I keep getting different suggestions as to what my options are so when i come back my pool water isn't completely ruined. Thanks for any suggestions.
    Default Re: need to cover my pool for 6 weeks while i am away...help with chemical suggestion
    For ease of installation and protection, a solid 'tarp' cover will do what you need.
    If you have questions about securing it or treating the water, prior to your departure, simply ask.
    Aug 2010
    My question IS about how to treat the water. Suggestions???? It will be closed for about 6 weeks - and it is summer. Thanks.
    There are others here who could tell you exactly what and why to dose the pool - I'm not one of them However, if you'd kindly give us a full set of test results, even I can tell you where to get the levels before you cover the pool for 6 weeks. Basically, you're 'winterizing' the pool for 6 weeks in the summer, you need to have adequate chlorine and be sure that your other levels are good for that time period.
    You'll probably want to shock the pool and then let it drift down a bit and then maybe add a double dose of polyquat 60 and put your filter on circulate for a day or so. Then bring your chlorine back up a bit before covering it but not to shock level. You don't want to cover a pool that is at shock level as the fumes can damage the cover. I would also take the pH to the upper end of normal like about 7.8. Having said that, let's see what Ben recommends. He'll give you the best advice in this situation. I'm going to ask him to take a look at your thread.
    Aug 2010
    Thanks for your suggestions. I called a few pool companies and they said to balance & shock the pool then put in a winterizing pill as well as some long acting algeaside then two floating chlorine floaters filled with as many slow tab's as they take..probably 3 each. Does this sound okay???
    Lehigh Valley, PA
    We routinely leave our pool for 6 weeks in August/September. We'll in eastern PA, same weather as you in NY. We bring it to shock level the night before we leave and add polyquat 60 the next morning, then put the solar cover on. We don't have a winter cover or we'd use it. We turn the pump off.
    Yes, it's green when we get back. Not a big deal. We dump in 3 large jugs (182 oz) of bleach the day we return and turn the pump on. After a couple of days of steady high concentrations of bleach the water is clean again, albeit cloudy. We keep the pump running, backwash/rinse the filter, might brush the bottom, and within 10 days the water is clear again.
    Unless you can hire a pool service or someone to dump some bleach in and agitate it in the water (tough to do with a cover on) you may just have to accept you'll have a green pool. If you use BBB, that should not be an obstacle because a green pool is easy to fix.
    I don't know what is in the winterizing pill and wouldn't use it. I also would definitely not use any algaecide other than polyquat 60. Many of them cause a lot of other problems to clean up including foaming. We never recommend any other type of algaecide.
    Honesdale PA
    If you can get the pump on a timer, just being able to run it for an hour, twice a day in recirculate mode, will help. With a cover, and this time of year, you shouldn't have to worry about evaporation dropping the water level and sucking air in the skimmer. I also say recirculate because you don't want the filter plugging. All you want to do is kick the water around. Of course having someone come in whenever possible and check the basic chemistry would be ideal.
    Aug 2010
    i ordered a 90 day strength algaeside from a company online that i probably cannot name here. wondering this item has the same active ingredient as the polyquat 60 that your talking about.
  1. Winter closing IG BBB Safety Cover - Best Chemical Balance prior to closing?
    By blue wolverine in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-16-2012, 04:36 PM
  2. I will be gone for two weeks...what to do with my pool?
    By True Blue in forum Pool Equipment & Operations
    Last Post: 06-17-2011, 06:30 PM
  3. Need new 24' AG solar cover, any suggestions?
    By famdog in forum Above-Ground Pool Construction & Repair
    Last Post: 06-11-2007, 01:46 PM
  4. any suggestions on using a cover on a small AG?
    By rastoma in forum Above-Ground Pool Construction & Repair
    Last Post: 08-18-2006, 10:29 PM
  5. Tips, suggestions on what type of solar cover to buy & where?
    By MTU 5.0 in forum Pool Equipment & Operations
    Last Post: 07-14-2006, 10:53 PM
