Thread: Inground Pool light fixture problem
    Jun 2011
    Default Inground Pool light fixture problem
    Hi,
    I have a concrete inground pool built in early 1980's and my light fixture is malfunctioning due primarily to age...It is corroded.
    My light casing is 8 1/4inch in diameter and 10inches deep. I am looking for a similar fixture that will fit in there...anybody has an idea?
    I could potentially purchase a bigger one but I would like to know how you to increase the size of the opening (remember it's concrete!) and do a pretty good job...Most new light fixture are over 10 inches so I would need to extend the hole by at least an inch on each side...
    Let me know
    Mo
    Default Re: Inground Pool light fixture problem
    Generally, you'll need a fixture like the one you are replacing; the light niche is not normally replaceable without a huge amount of work.
  1. sludge/goo behind inground pool light
    By Schooled by Pool in forum Dealing with Algae & Slime
    Last Post: 06-01-2013, 03:11 PM
  2. Light Fixture Troubleshooting
    By wingsfan in forum In-Ground Pool Construction and Repair
    Last Post: 05-18-2012, 12:03 AM
  3. Inground pool light question
    By waldreps in forum Pool Equipment & Operations
    Last Post: 07-18-2011, 05:14 PM
  4. Light fixture, uhoh.
    By frankief in forum Pool Equipment & Operations
    Last Post: 06-02-2007, 09:11 PM
  5. problem with two inground pool jets
    By bpbynum in forum Pool Equipment & Operations
    Last Post: 09-19-2006, 04:43 PM
