Hi Luggon;
If your pH has been low, your heater can definitely be the source of copper. However, I'm somewhat suspicious of the number you report (3.5). You didn't give units, but if you mean 3.5 ppm . . . you almost certainly already have visible stains. If you mean 3.5 ppb . . . it's a bogus result, unless you had the water tested at a genuine water analysis lab, and I do NOT mean a pool store. In any case, 3.5 ppb would not be a problem.
So, the question is, how did you get that number, and what are the units?
(And Janet is 100% correct: there is NO copper in 20 Mule Team Borax.)
Best wishes,
Ben
