Thread: White cloudy water
    Jun 2011
    Inverness, Alabama
    Question White cloudy water
    I just installed a new sensor on my salt chlorinator system. I have been using the standard chlorine method while I was going through the trouble-shooting/tinkering/ordering phase of this dilemma. When I got the sensor installed and turned the system on, it immediately made the return water a white cloudy consistency. It has been doing this for two days.
    Any thoughts on this anyone?
    TIA
    Default Re: White cloudy water
    Does it clear up after the SWCG is off, like maybe it's air bubbles making it appear cloudy?
    A "sensor" would not itself have any affect on pool water.
    Can you provide more specific info about what SWCG you have, and what sort of sensor you installed?
    Jun 2011
    Inverness, Alabama
    Default
    It clears up when I turn the SWCG off.
    It's a Chlormatic 3 and a Chlormatic three sensor. The Salt Cell Generator is Jandy (Aquapure). They are all compatible, so that isn't an issue.
    Ft Lauderdale, Fl
    The cloudy water condition is coming from the cell. It's not a hazardous condition, just unsightly. You can try sending more water through the cell, lowering your pH, or if the cell is close to the heater outlet and the heater is on, move it further downstream.
    Sean Assam
    Jun 2011
    Inverness, Alabama
    Quote Originally Posted by Poolsean View Post
    Well, I don't have a heater and the pH is within normal limits. (It doesn't seem to be causing any problems at the moment.)
    Thanks for the info!
    Ft Lauderdale, Fl
    What are you considering "normal limits"? Industry standard says the normal range is 7.2 - 7.8, which is quite a spread, when you consider that it can factor into the overall water balance of your pool.
    What is your overall water chemistry, so we can determine the saturation index?
    Total Alkalinity, Calcium Hardness, Water Temeperature, pH?
    Sean Assam
  1. White cloudy water
    By bb158 in forum Dealing with Algae & Slime
    Last Post: 06-07-2013, 10:16 AM
  2. White Cloudy water
    By billbeard78 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-07-2012, 10:49 PM
  3. White foam on cloudy water
    By crsuarez in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-06-2007, 05:59 PM
  4. White Cloudy Water - Twighlight Zone
    By szampino in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-30-2006, 01:24 PM
