Hey guys. Ok so the pool is clean. After being drain cleaned and filled with new water the filter is on. I used my Taylor just now and here are the initial readings:
Ph 8.0
.5 ppm fc
No tc
Ta 80 ppm
1200 ppm calcium hardness
Sorry if I am posting them a bit weird. The dot test the dot never disappeared. Sorry I forget the test name.
As a reminder the pool is 24ft above ground. I just added 4 gallons of bleach a few moments ago. Any suggestions would be great. I have some bubbles coming out of the return but I think it's just an air leak via the seal on the pump. I'll take a look tomorrow when it's brighter out.
Conventional wisdom is to add chlorine at dusk so all of it's energy is used in
