I have a powdery dust substance that settles on the steps and bottom. when I vacuum it stirs it up in clouds and also comes out through the jets. also when I backwash I can see it coming out of drain. I have a sand filter. I use chlorine granules, chlorine tablets in a release tube, soda ash, and pool perfect and aglaecide. all this once a week after I vacuum. my readings are normal and ok except ta is a little high. I just started using the chlorine tablets because my pool pro said I was supposed to be using those all along because they allow the chlorine to work.... does anyone know what this powdery substance is and what am I doing wrong. pool is cloudy. SOS new pool owner
