Results 1 to 10 of 17
Thread: Stained Vinyl Liner
    Cpagasky Guest
    Default Re: Stained Vinyl Liner
    I got my PH up to 7.5 after adding the Borax, but my Chlorine seems to have dipped to near 1. I was going to try to elevate the chlorine to 15 to do the shock you recommended to make sure the stains aren't algae related. My pool has about 28500 gallons. How much bleach do you think I'll need to add?
    To go to 15 ppm on a 28,500 gallon pool with plain 6% household bleach, you need about 9 gallons.
    But, I'm going to suggest something more cautious. The problem is that while high chlorine will often remove organic stains, it will tend to make metal stains WORSE.
    So, before you take the whole pool up to 15 ppm, can you locate an area that is shallow, and has the staining? If so, take a synthetic (NOT cellulose!) sponge, and put it in a baggie that will fully enclose it. Pour in enough bleach to saturate the sponge. Then put on your old swimsuit and some plastic gloves and get in the pool (unless you can reach it from the side). Take the baggie to near the stain, open it, and quickly place the sponge against the stained area. Compress it somewhat against the stain, and wait 30 - 60 seconds. Remove the sponge, and see if the stain is better or worse.
    Cpagasky Guest
    It seems that you were correct and the stain was in fact an algae of some type as after the first night with the Chlorine at 15 most of the stain disappeared and the filter pressure had gone up from filtering the dead algae, I'm guessing brown or black. After getting my pH to stabilize, I increased my Chlorine to 15 by adding the 9 gallons of Bleach. I've had trouble keeping the Chlorine at the 15 ppm level, I"m almost thru the third day and I've added an additional 7 gallons of Bleach to try to maintain that level. I will say that about 85% of the stains have been removed and I'm hoping that if I keep the level at a shock that remaining stain will be removed as well. How long does it generally take to kill an algae of this type?
    Cpagasky Guest
    The Chlorine levels have been staying consistent with only 1 ppm lost last night. So it seems that I've eliminated the algae but there is still a small amount of stain remaining. Any ideas?
    Hold the chlorine up for at least 2 more days. You want to be sure the algae is completely gone, not just mostly gone.
    Meanwhile, we need to see about your total alkalinity. It would be easiest to manage both your alkalinity and your chlorine if you have a Taylor K2006 or one of the few other complete kits with FAS-DPD testing. If you don't there's an Amazon link for the Taylor in my signature.
    How did you get the 185ppm reading? (I'm asking, because I don't know how much to trust it.) If it's reliable, you need to try to hold your pH in the 7.0 - 7.2 range.
    Cpagasky Guest
    I'm using the HTH 6 way test kit to test my alkalinity. I have one of the simpler taylor kits that I've used for chlorine along with some of the less reliable strips to test at the top levels. I need to order the better taylor kits but haven't done it yet.
    As for my original problem, I'm thinking that I had an underlying stain that was compounded with algea, as I've kept the Chlorine levels in the shock mode all week and there remains a yellowish brown stain but the chlorine levels are no longer dropping overnight like they had originally.
    Let me know if I should go ahead and get the taylor kit now, I was hoping to limp through with this one but at this point I'll get it if necessary.
    Cpagasky Guest
    Thanks for the reply Yeggim, I went ahead and ordered the k-2006 this morning.
    TomC is offline PF Supporter Thread Analyst TomC 0
    New York
    I know this is just stating the obvious, but here goes.....Make sure that in addition to chemically attacking that algae, you are physically attacking it too. Get out the brush attachment for your skimmer pole and every morning brush the liner areas where the algae thrives. My apologies if you are already doing this.
    Tom
    Cpagasky Guest
    No problem Tom, I have been brushing it and I'm leaning back toward my initial thoughts of this being a stain as opposed to algae. I had kept the pool at chlorine shock levels for seven days and the levels have remained since. I think there may have been some algae originally as I had some issues getting my chlorine correct early in the year due to large amounts of rain but the stain was always hiding under it. I may just live with it through the summer and try to work on it later in the year when I can lower the chlorine levels and use some stain remover. Let me know if anyone has any better ideas. Thanks
