Results 1 to 10 of 19
Thread: Salt Water Pool Water Smells Like Must
    Smile Salt Water Pool Water Smells Like Must
    I have been a long supporter of Pool Solutions and Salt Water Generators. However over the past 3 years I have noticed that when you get out - your skin smells like must / bad odor. My wife wants to take a shower when she gets out. I have increased my chlorine and have even replaced all of the water three years ago with a new liner. This year I dumped 5,000 gallons and replaced with new water. Still have the smell. I was wondering if anyone else is having this problem or if they know of a fix. Following please find my measurements that I took tonight with the PS232 Kit. 6/20/11
    15,000 gallon Vinyl Pool Zodiac Salt Water Generator Located in Indianapolis IN
    FC 14
    CC .5
    PH 7.7
    ALK 170
    CYA 110
    Calcium 180
    Water Temp 78
    Salt 4,000 PPM
    Water is Clear
    Appreciate any input!!
    Thanks,
    Devon
    Ft Lauderdale, Fl
    Default Re: Salt Water Pool Water Smells Like Must
    A "smell or odor" is pretty subjective.
    However, why are you keeping your chlorine level so high? Your water chems seem to out of balance too. TA is high (should be down between 80 - 120 ppm, with my preference at 80 - 100 ppm). Cya is much higher than even allowable by commercial pool standards. This should be down around 60 - 80 ppm. Calcium Hardness may not factor too much into this as you have a vinyl liner pool, but you should still maintain balanced water conditions (according to the saturation index).
    The smell may be resulting from the FC at 14 ppm having some bleaching effects on clothing or your liner...just a guess.
    Dilution is the solution to getting the cya, ta, and FC levels down quickly...and would be my first step.
    FWIW, I have a Pool Pilot on my pool, without any of the smells you're describing. I do maintain about 75 ppm cya, at 2 ppm. TA is frequently below 100 ppm, and Calcium hardness is around 350 ppm. pH kept at 7.4
    Sean Assam
    Sean,
    Thanks for your input. I will dilute and see what happens. I have always had problems getting my TA down. Do you know of any tricks.
    Thanks,
    Devon
    Almost sounds like you are smelling brine, like at the ocean. I find brine kind of musty smelling, but at the ocean you don't think about it...It's the BEACH!!!!
    Is the salt level at the high end for your SWCG?
    Lehigh Valley, PA
    Well yah, especially in NJ where the "beach" can smell like just about anything
