Results 1 to 10 of 12
Thread: Chlorine Lock
    Jun 2011
    Virginia Beach
    Default Re: Chlorine Lock
    Vacuumming was to aid in clearing the water. I would only do this if there is actually something to vacuum.
    But for now, I should just concentrate on the chlorine?
    Jun 2011
    Virginia Beach
    Ok, pool is still cloudy. While vacuuming I ran across an area that threw out some green stuff. A small area maybe four feet in diameter and kind of in the middle.
    But, I received my Taylors and:
    FC = 2ppm
    TC = 1ppm
    PH = 7.4
    TA = 170
    CH = 120
    CYA = 30
    Saturation Index = -1.15
    Water Temp is 90 according to my meat thermometer
    Water is cloudy.
    Your TA is too high, but nothing to worry about at the moment . . . except that you'll need to keep adding acid to keep you pH below 7.8
    BUT . . . your chlorine is too low! Are you adding 2 gallons of bleach each PM?
    If you have the Taylor FAS-DPD test kit you cannot get "FC =2 and TC=1". Perhaps you mean CC= 1 rather than TC?
    Rule: TC = FC + CC. Therefore TC can NEVER be less than FC.
  1. Chlorine Lock
    By wellioughta in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-11-2011, 12:07 AM
  2. chlorine lock?
    By skimmer in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-08-2011, 08:40 AM
  3. Pool guy says Chlorine Lock?
    By Mwil3 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-28-2010, 10:31 AM
  4. Help!! I don't know who to believe - Chlorine Lock?
    By btozzo in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-24-2010, 05:31 AM
  5. Chlorine Lock ????
    By poolrescue30 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-18-2008, 06:12 PM
