Using the K-2006
I picked up this kit today. Rushed home and took a water sample. Sat down and opened the kit.
The FC test. Stumped from the gate.
The yellow instructions confused me.
It says:
For 1 drop = 0.2 ppm, use 25mL sample.
For 1 drop = 0.5 ppm, use 10mL sample.
I used the 25mL sample but I think the 10mL would have saved me some indicator.
How do I know which sample size to use?
I only tested for FC, CC, PH and CYA because to be honest, it is way more complex than I expected.
I am reading the guide and I understand the SI should equal 0, but without the TA and CH tests I can't know that yet. Maybe tomorrow.
My numbers look good
FC=5.6
CC=0
PH=7.4
CYA=42
The CYA, good lord - I could be off 8 to 10 points with that thing.
Any tips on doing that test?
So now what. In the past I used chlorine tabs in a floater but from reading this board I am tempted to go with bleach. Fear of the unknown has me in its grip.
Bleach pros and cons?
Advice appreciated.
Circa 1980 IG, VL, 36K Gal, DE, Chlorine
