Results 1 to 10 of 20
Thread: Fighting Cloudy Water: 4 Weeks and Counting
    Jun 2011
    Franklin, TN
    Default Fighting Cloudy Water: 4 Weeks and Counting
    Hey all,
    This is my second post, as I'm a new pool owner and new to the PoolForum, so I need lots of help.
    My pool (20,000 gal.) was an absolute swampy mess when I opened it just over 4 weeks ago. Unfortunately, I made the mistake of calling a local pool company to help me open it (before I discovered the Forum) and got ripped off. Anyway, they put in 20lbs. of shock, which after 4 days, 3 more pounds of shock and 4 trichlor pucks, killed off the green and allowed me to at least kind of see the bottom. I also cleaned the majority of junk out of it.
    Unfortunately, I had not received my Taylor test kit in the mail yet and had to go out of town for a week, so I left the pool completely unbalanced. And, of course, got home to another green mess. Since then, I have reshocked the pool and killed off the green, but the water is still completely cloudy. I have read a lot of info here and on the sister site, and have been learning the ropes of testing, but I need to now where to go from here.
    Here are my recent results:
    6-19-11 (6:00pm)
    FC = 0
    pH = < 7.0
    TA = 20
    CYA=0
    Added 3lbs. Borax
    6-20-11 (7:30pm)
    FC = 1.0
    pH = <7.0
    TA = 10
    CYA=0
    Added 3lbs. In the Swim super shock (73% CaHypo) + 2 trichlor pucks in skimmer + 4lbs. CYA (@ 7:00pm)
    6-21-11 (7:30am)
    FC = 10.5
    pH = <7.0
    TA = 20
    CYA=<30
    [No change in water cloudiness]
    Pool Stats: 20,000 gal., vinyl liner, Hayward S200 sand filter, broken heater
    Please help!
    Thanks,
    Andrew
    Default Re: Fighting Cloudy Water: 4 Weeks and Counting
    Hi, and let me thank you up front for supporting the site with your subscription!!
    I see a couple of things you need to fix...
    First off, a pH less than 7.0 is acidic and can damage your liner. If 7.0 is the lowest your kit registers, there's no way to know just how much lower it actually is, so you need to be adding Borax and retesting until you get a pH above 7.0. Granted, pH reads falsely high when chlorine levels are high, but that just means your pH is lower than you actually think it is. Add Borax, give a couple of hours to circulate, retest, and add more until you at least get a reading higher than 7.0.
    Second, you're using Cal-hypo to chlorinate, but you don't list a hardness level. If it's too high, your cloudiness can be coming from calcium. Run a test for that and see where it is.
    Third, what size pump do you use with your filter, and do you see particles blowing back into the pool? Is your pressure gauge indicating a pressure rise as you're filtering? How often are you backwashing it? Have you backwashed it since you added the stabilizer?
    When you kill off an algae bloom, the chlorine will kill the algae, but it takes filtration to remove it from the water. There can be a huge amount that needs to be filtered, and if your filter isn't working properly, or is overdriven by your pump, that can severely hamper the filter's ability to clear out the dead algae. Sometimes it's just trial and error to see what's wrong, but if you can post answers to the above questions, we'll try to help you get it figured out.
    May 2011
    Massachusetts
    Andrew - I am by no means an expert and have only learned in the last few days what low PH, a broken heater, and a vinyl liner can do to your pool. If you look about 9 posts down on this main forum - "Major Chemistry Problem..." you can see all the issues I had.
    Jun 2011
    Franklin, TN
    psciotti-Man! Sorry you had such a nightmare. I haven't even made it all the way thru your thread yet, but hope you got it worked out. I am 99% sure my heater is shut off, but I'm going to check to make 100% sure it's being bypassed.
    May 2011
    Massachusetts
    It's amazing the stuff you learn to pay attention to only when trouble happens. Anyway - I'm almost home thanks to the great people on this forum. Check out the BBB method and avoid all the other stuff... I am a true convert after my issue.
    Jun 2011
    Franklin, TN
    Thanks for the reply Janet.
    Sorry for the delayed response. We've had a lot of rain so it's been tough to tend to the pool.
    Good news is I can see the bottom!! At least in the shallow ... and partially in the deep. Also, Ca Hardness is within acceptable range: 130ppm on 6/21 and 150ppm as of 7:00 tonite. Bad news is it seems to be rising. Here are the rest of my readings from the last couple of days:
    FC: dropped from 10.5 on 6/21 to 4 tonite.
    pH: still too low, but rising. Added 1.5 boxes Borax in the last 24 hrs.
    TA: holding steady @ 20
    CYA: gone from no reading to 40 as of this AM
    Here are the answers to your other questions.
    -Pump: Based on the label I can read, A.O Smith Century Centurion 230V / 6amp.
    -No particles blowing back into the pool
    -Pressure gauge is completely shot. I've ordered a new one that will hopefully be here soon.
    -I have backwashed a lot because of the algae and it seemed to help the leak on the top of my filter. Initially once a day, but now maybe twice a week.
    The sand probably needs replacing since it's 10+ years old, but I really don't want to have to undertake that right now if at all possible to avoid.
    So, what should be my next steps? Keep getting the pH up obviously, but should I focus on the TA? Should I add a puck to the skimmer since the chlorine's dropping? Oh, also, I spread the stabilizer directly into the deep end, and it looks like a bunch is still just sitting on the bottom. Guess I should've diluted, but nothing about that on the package label. Thoughts?
    As always, thanks for the help.
    Andrew
    I'm not Janet, but maybe I'll do! (She is working this evening and it may be tomorrow til she is able to answer, so thought I'd take a crack at it for you.)
    If your CYA is at 40 but you still have undissolved stabilizer in the pool, that means that your CYA level is going to go up higher than 40. Therefore, you don't want to use any forms of stabilized chlorine which means no pucks. They are stabilized and will cause your CYA to continue to rise. You also don't want that CYA laying on your liner. Vacuum it up into the filter. Since your CYA is at 40 which is a good level, I'd go ahead and backwash it out.
    Since your calcium hardness level is ok you can use cal-hypo for awhile if you want but if it were me, I'd just use bleach. Bleach will never contribute to cloudy water problems.
    Did you order a test kit? If not, I'd recommend that you do so. While your water is cloudy, I'd suggest raising your cl up to shock level which would be about 15ppm. In a 20K pool, each gallon (4 quarts) of 6% bleach will add 3ppm of chlorine. Every time you test which should be at least morning and evening for now, add enough bleach to get the cl back up to 15. You need to keep it at shock level until you can go from sundown one evening to sunup the next morning without losing more than 1ppm of chlorine, and you have no more than 0.5ppm of CC (combined chlorine.) Do you have a CC reading by the way? If so, post it. We really need to see it.
    Since your pressure gauge hasn't come in yet, you'll have to just judge when to backwash by the pressure of the water coming out of the return. When you feel a substantial decrease in pressure, backwash. Run the pump 24/7 while you are trying to clear the pool.
    Not necessary to change out the sand.
    Keep working on the pH. You don't have to wait too long between additions of Borax. After adding some, wait a couple of hours, retest and redose. You need to get it above 7.0 ASAP.
    Your alk is also low. Add some baking soda to the skimmer to raise it. I'd start with about 3 lbs. at a time. As with the Borax, retest after a few hours and redose until you get somewhere between 80-120. By the way, it is ok to add baking soda, borax and bleach one right after the other.
    Hope this helps. Keep us posted how things are going.
    Jun 2011
    Franklin, TN
    I do have a test kit: Taylor K-2006.
    As for the chlorine, my issue is that I already bought $80 worth of pucks before I found this forum and started learning about the BBB method. That's a lot of money that I can't afford to waste. So, do you have a recommendation as to how I can incorporate all that stabilized chlorine? Start using them again once my CYA is steady? Do I need to use bleach in the short term until the CYA is steady?
    I'll pick up some baking soda tonite to work on the TA.
    Update you tonite/tomorrow.
    Thanks,
    Andrew
    Unlike chlorine or pH which have to continuously be added and adjusted throughout the summer, once you get CYA in your pool, it lasts. Some people's pools even keep the CYA throughout the winter; others don't and lose it and have to add CYA again the next year.
    Bottom line is that if you continue to use the pucks this summer, your CYA is going to continue to go higher and higher and higher As a result, you're going to have to keep your chlorine levels at higher and higher levels or you'll get algae. (Take a look at the Best Guess table in my signature below if you haven't already done so.)
    You can keep trichlor tabs from one season to the next. Keep them tightly closed in the original container in a cool place and then if you need to add CYA another year, you'll have them.
    Glad to hear you have the kit. That will make things easier for you.
    Hope this helps you.
    Jun 2011
    Franklin, TN
    Ok, so here's the latest.
    6-24-11 (7:30am)
    FC = 2.0
    CC = .5
    pH = 7.4 (woohoo!)
    TA = 20
    CYA = 35–40
    6-24-11 (7:30pm)
    Added 4.5 gallons of bleach and 3 lbs of baking soda.
    Didn't get to test last night. Long story.
    6-25-11 (7:30am)
    FC = 11.5
    CC = N/A (forgot to test)
    pH = 7.6–7.8 (boo)
    TA = 60
    So, some good news. Not sure why the pH went up so much, because I haven't added any Borax in over 36hrs. Should I add some pH reducer or just let it ride for now? I'm going to add some more baking soda today. Any reason why I can't add it now if it's overcast because I have to be gone from the house this evening?
    Thanks,
    -A
  1. three weeks and still fighting
    By chuckerman in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-05-2011, 07:03 PM
  2. Sky Blue water - cloudy going on 4 weeks
    By LP Heaven in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-30-2010, 06:01 PM
  3. Fighting Something. . .
    By PhantomAndy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-05-2006, 11:08 AM
  4. Fighting with PH
    By Koz in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-24-2006, 11:26 PM
  5. first opening with new house, cloudy water for 3 weeks
    By gordyjamz in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-15-2006, 07:24 PM
