Results 11 to 20 of 22
Thread: Newbie...been reading..need specific advice
    Default Re: Newbie...been reading..need specific advice
    Take a look at the Best Guess chart in my signature below. With a CYA of 40, you'll want to maintain your chlorine levels between 3-6 ALL the time. If you drop below 3ppm, you risk an algae bloom. So, each evening, add enough bleach to get back to around 6. If you find at the next evening's testing that you have dropped below 3, maybe go just a little higher for the evening dose. (Maybe try 7.)
    Jun 2011
    Fort Worth, Texas
    Gotcha...I will keep you in the loop on this.....Algea scares me...
    Jun 2011
    Fort Worth, Texas
    Guys and gals....
    This BBB method, is awesome! A few questions....
    1. My water is in perfect shape per my taylor 2006c test kit (CC, TC, PH, CYA, etc).....So, how often do I need to shock? 18,500 gallon pool, means to my fuzzy math......1 gal bleach=6 ppm on a 10,000 gal pool..so I need...6 gal of bleach to get above 15ppm on my 18,500 gal pool?
    2. Water softener? Thoughts? Ideas? Am I retarded? The guy who installed the pool put something in the pool and it made it feel silky smooth....no idea what it was.....
    3. I can not find polyquat 60% here in DFW? Any ideas?
    4. Anyone use this for a timer on their pool pump...http://www.honeywellcentral.com/prod...-timer-ti1062u
    charles
    #1 - On your pool, 1 gallon = ~3 ppm chlorine
    #2 - It's a matter of perception, but to some people, pools with salt feel that way. Borax also has somewhat similar affects, once you start getting above 50 ppm borates.
    #3 - It's getting hard to find locally; it's still available online.
    #4 - You'd better watch the inductive (motor!) load limit. It is listed for a 1HP motor max, but my experience has been that consumer grade electronics don't do well when you max them out.
    Jun 2011
    Fort Worth, Texas
    When should I shock the pool? Once a week? After heavy usage? What do you all do?
    Many thanks in advance..
    Charles
  6. #16
    drband's Avatar
    drband is offline Lifetime Member Thread Analyst drband 0
    Gainesville, GA
    Most of the time, I only shock when CC is > .5 but I will shock after a very heavy rain storm. If you are able to keep your CL in the recommended range (Ben's chart) you may not need to shock very often at all! Good luck.
    10,000 gallon IG vinyl liner pool, BBB user, salt added to 2300 ppm (because it makes the water feel great!), new liner/new water on 6/23/11, algae-free since 2006 (at least that's as far back as I remember). 1HP Hayward 2-SPEED CONVERTED Superpump, Hayward sand filter, PS234 test kit.
    Goal: To remain completely algae-free for the life of this new liner!
    Life lesson: It is what it is.
    12'x24' oval 9K gal IG pool; bleach; Hayward 244T sand filter; Hayward Super pump, 1 HP, 2-speed pump; 24hrs on low speedhrs; PS234; utility water; summer: ; winter: ; android phone; PF:13
  7. #17
    Jun 2011
    Fort Worth, Texas
    FC last night was .6, so I added qty 3, 96 oz bottles of 6% bleach...roughly 2.25 gal....so in my head, I think "pool is 18,500 gal..so...7.4 PPM FC is what it should be in the morning"...
    Go back out this morning, re-test...7.4 FC..dead on....0 CC
    Tonite...I get 4.6..0 CC....
    CYA is hovering around 50 in my Taylor 2006C test kit...(all numbers stated have been double tested)
    I am needing to add 1 gal of bleach in this Texas heat....sound right?
  8. #18
    Jun 2011
    Fort Worth, Texas
    tested this morning, and it was a 3.0 fc and 0 cc....cya between 40 and 50....on my tester in the kit....
    Should i be averaging 1 gal of bleach a day, or should i raise my cya?
    thanks in advance...
    charles and family..
  9. #19
    I don't think a gallon of bleach a day in this size pool is excessive. I have a 13K gallon pool and I add 2 to 3 quarts per day. However, you may want to bump the CYA up a little. It would allow you to add bleach a little less often.
  10. #20
    I think a gallon a day sounds about right...but I would suggest bumping up the CYA just a little. I'm near Shreveport, so have the same climate as you. I intentionally run mine around 80-90 in order to slow down my chlorine consumption, and this season have been adding the large size WalMart jug (1.4 gallon, I think?) every two days. Might try bumping it up to 60 or so and see if that helps....
  1. Confused Newbie needs CYA advice
    By dognostrils in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-16-2012, 11:07 PM
  2. advice on specific pools I'm considering
    By badutahboy in forum Above-Ground Pool Construction & Repair
    Last Post: 01-31-2007, 01:59 PM
  3. Newbie needs advice....so confused
    By AndieP in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-08-2006, 08:44 PM
  4. newbie in need of advice
    By gaineycruzin in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 07-03-2006, 12:12 AM
  5. Newbie needs help/advice
    By poolgal in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-16-2006, 02:51 PM
