Hi,
In the desert where I live the water is hard and it's necessary to drain your pool every several years. I'm at that point, as my pool just gobbles up acid with nary a swing in pH. Can't do it now though because in the summer the 100+ degree heat would damage the plaster. So I want to drain a little at a time. Maybe I can do this more efficiently if I target either the water near the top -- skimmer -- or bottom -- main drain. Would the calcium and other minerals tend to float upward (seems unlikely but that's only a guess), or to settle to the bottom?
Thanks,
Ted
