NOTE TO ALL: This poster's pool is INDOORS and is functionally a SPA, not a POOL (95 degrees year round). The standard advice we give here does NOT apply!
Hi Millhouse;
Not so short answer on how to clear it:
# drain it, and refill.
After 2 years of use, a spa is long overdue for a drain and refill. Un-filterable, un-oxidized residue builds up in spas because they are not UV-irradiated and are much smaller relative to the bather load, than pools. However, before draining, add 4 full gallons of plain 6% household bleach and allow it to circulate uncovered for 6 hours or so BEFORE you drain. You will probably need to make sure windows and such are open before you do this. If you can't do so, add the bleach AFTER you refill, and then dechlorinate with hydrogen peroxide (BaquaShok)
# ditch the Nature2 cartridges.
The only possible positive effect of Nature2 is anti-algae, and to prevent growth of bacteria like Legionella (http://en.wikipedia.org/wiki/Legionella). But algae is not a problem on indoor pools, and if you chlorinate effectively that will never be a problem. Worse, it's unlikely the Nature2 units are working for that purpose. If you want to use copper on your unit, using plain copper sulfate would be a better choice. Under certain conditions, like when adding acid, the Nature2 units may unexpectedly release copper into the water.
# forget about bromine.
I'm going to ask Chem_Geek to look at this, but I'm not aware that there is any substantial support for the marketing claim that bromine works better at higher temperatures.
# replace your filter cartridge
Essentially for the same reason you should replace your water.
# limit future water treatment to 5 chemicals, and no others:
1) plain 6% household bleach (to chlorinate)
2) muriatic acid (to lower pH)
Dilute 1 part acid to 3 parts water BEFORE storing. (Be VERY careful. Do this OUTDOORS, while wearing gloves and glasses. Have a running water hose beside you to rinse way any splatters. Do NOT breathe the fumes.) Once diluted, the acid will no longer fume, but still should not be stored indoors.
3) borax (to raise the pH)
4) hydrogen peroxide (to dechlorinate)
5) polyquat algaecide (used at 2x the listed dose to 'keep' the pool any time you plan to neglect it)
# reduce skin and eye irritation with borax, and possibly with salt.
50 - 100 ppm borax will inhibit growth and reduce eye / skin irritation somewhat. Up to 5,000 ppm salt will reduce both significantly . . . but check with the manufacturer -- adding salt may void your warranty.
# do NOT use any of the 'special' spa or pool chemicals.
Many of these are a hobo-soup of chemicals with unpredictable results, or create known long term complications.
# plan to drain the spa 100% at least every 6 months
(I'm assuming it is used regularly)
# monthly, shock to 20 ppm (about 1 gallon of bleach) and then dechlorinate
after 8 hours or more. Leave the spa uncovered during this period and ventilate the area
# if you want to reduce odors and negative effects further, you can try 20 - 30 ppm stabilizer,
which will enable you to maintain higher chlorine levels without damaging swimwear or affecting eyes.
# get a Taylor K2006
so you can accurately test your water yourself. Use it to work out a routine so that chlorine levels can be maintained consistently. Levels should never, ever be below 1 ppm.
# if your spa is private, ask your wife to skip the suit.
Not only will this eliminate the suit deterioration issue, it will eliminate the skin and sanitation issues that come from half-dried suits used on indoor pools.
Obviously, there are specifics here I haven't included. But if you want to follow this plan, let us know and I'll work out the details.
