Thread: Are chlorine skimmer sticks or pucks OK?
    Jun 2011
    Default Are chlorine skimmer sticks or pucks OK?
    Is it safe to put chlorine sticks or pucks in your pool skimmer? Friend of mine says yes, pool installer does not recommend it. Says it will eat your skimmer housing out....Who is right. thanksfi
    Default Re: newbe here with guestion.
    It is fine to put pucks in the skimmer as long as you run the pump 24/7. If you turn off the pump, remove them from the skimmer. They are very acidic and you don't want a high concentration of acidic water sitting in there. You would also want to remove the pucks if you are adding anything to the skimmer other than Borax.
    Welcome to the Pool Forum!
  1. Floater pucks VS Skimmer pucks
    By ThaSatelliteGuy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-16-2011, 07:11 AM
  2. 99% Chlorine Pucks
    By singinginmycar in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-27-2010, 05:00 PM
  3. Chlorine Pucks
    By donfranko in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-25-2007, 12:04 PM
  4. Chlorine pucks
    By hancop in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-23-2006, 03:00 PM
  5. Skimmer Sticks... why so expensive?
    By leejp in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-18-2006, 09:33 AM
