Results 11 to 13 of 13
Thread: Plug? Strong suction leak in liner.
    Default Re: Plug? Strong suction leak in liner.
    Thanks, Connie;
    Check back later today -- I just grabbed those photos and will slice and dice them to make some of the aspects of what you encountered clearer to future readers..
    Regarding moderation, it's been a necessary evil. Now that things are beginning to slow down, I've already begun work on a major overhaul of my firewall, and installation of a vBulletin mod (BadBehavior) that will allow me to loosen some of those restrictions. Ironically, we *still* may not be able to do so. My mods and I were close to our limit as it was, responding to posts. If I'd fully opened the doors we would have been overwhelmed. The result would likely have been unsatisfactory to all.
    Not sure where we'll end up on all that.
    Hey Connie, glad to have tried to help you.
    I hadn't realized that your hopper was trashed. A new liner and a LOT of bottom work are in order But DO address the water issue first with a well point!
    If you really want to help anyone else who has this issue, please tell us how you end up resolving the issue. (the drain plug is not a permanent fix - the base will continue to wash out and the plug will just wash out under the liner.)
  1. Suction Air Leak Causes Skimmer to Spew
    By chuckerman in forum Above-Ground Pool Construction & Repair
    Last Post: 06-10-2012, 08:20 PM
  2. Suction Leak Causes Pump to Run Dry
    By mwagner in forum Pool Equipment & Operations
    Last Post: 08-24-2007, 02:53 PM
  3. Suction Side Air and leak
    By lcrooks in forum In-Ground Pool Construction and Repair
    Last Post: 05-13-2007, 12:02 AM
  4. My suction side leak Saga
    By lmnharris in forum Pool Equipment & Operations
    Last Post: 08-24-2006, 05:57 PM
  5. Suction side leak (PIC) am I close???
    Last Post: 08-15-2006, 04:49 PM
