Too much info - it's not possible! THANK YOU for your detailed post!!!!!
You've got a high, ground water issue (that ought have been addressed during the build)
You need to get a sump pump, or similar, to automatically turn on - when the water is too high to keep the 'spring' from rising too much and disturbing your floor and liner.
I think the pipe you mentioned is a temporary one and ~ might be usable, but it depends on how they installed the 'well point' ( & you thought you gave too much info)
If you just go with a new liner, you'll keep having the same problem, until you fully address the 'spring' issue.
I'll help, as well as I can... but I'm not an expert in this(however, some other folks here are
