Thread: Intex 1.5 inch hose adapter
    Jun 2011
    Default Intex 1.5 inch hose adapter
    Hello All,
    I seen a post with an Intex adapter , Intex fitting to standard 1.5 inch Pvc threads the part number is 34560. I cant find much info on the fitting. What i am looking to do is keep the Intex hoses connected to the pool and hook the other end of the hoses to standard 1.5 inch pvc pipe. Can anyone help if this 34560 fitting will work or have any other ideas. Thanks in advance
    Brian
    Default Re: Intex 1.5 inch hose adapter
    Hi, Brian. I am not the plumbing expert on the forum. Not by a LONG shot. Not my department! But, somebody will be along to give you some advice. I just wanted to say hello and welcome you to the forum!
    May 2010
    322 Church St
    That's what you are looking for. I'm using them and they work great. The package comes with "2" adapters and thread tape.
  1. Intex 12 ft by 30 inch pool
    By TiffanyMcEwan in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-28-2012, 11:19 PM
  2. Convert intex pool from 1.5 to 2" hose
    By anIceFan in forum Intex-type Pool Setup & Operations
    Last Post: 05-28-2012, 08:46 PM
  3. Strainer / floor drain adapter for vacuum hose
    By coultond in forum Pool Equipment & Operations
    Last Post: 05-27-2012, 10:02 AM
  4. Polaris 65 return adapter question
    By penelopepitstop in forum Pool Cleaning: Manual or Automatic
    Last Post: 09-29-2006, 03:51 PM
