Results 1 to 8 of 8
Thread: Phenol red indicator question
    Jun 2011
    Reading, PA
    Default Phenol red indicator question
    My test kit came with phenol red R-0004, for use with 2000 Series Comparator. I wanted to replace the reagant when that I was at Leslies. They had R-0014, for use with Residential Series Comparator.
    The salesclerk at Leslies said Phenol red is phenol red so it doesn't matter. I am thinking that they are NOT the same since they have different numbers. The R-0004 does seem to be a darker red, but I don't k now the significance of that.
    What do the experts here think?
    18x33x4 foot oval
    Default Re: Phenol red indicator question
    It does matter. They are NOT interchangeable. You need the R-0004 for your 2000 Series Comparator. They are different concentrations because they are used in different water sample quantities.
    BTW -- Welcome to the forum!
    Lehigh Valley, PA
    One of them has a chlorine neutralizer in it, the other doesn't. I cannot remember offhand which is which.
    The BOTH have chlorine neutralizers in them, The difference is the R-0004 is more concentrated since it is used in a 44ml water sample while the R-0014 is used in a 9 ml water sample. The larger water sample in the 2000 series comparators provides better precision for the acid and base demand tests.
    Lehigh Valley, PA
    Thank you both for clarifying a misunderstanding I've held for some time.
    Jun 2011
    Reading, PA
    Thank you very much. I will get the R-0004 that was in my kit.
    BTW, when I purchased my house in 1998 the previous owner was using bleach for the pool. I don't know what else, but I guess he was a little ahead of the curve for his time. I didn't find the light until recently....and the BBB method is working great!
    18x33x4 foot oval
    Quote Originally Posted by Collector680 View Post
    That's what we like to hear!
  1. Taylor Phenol Red R-0014 vs R-0004
    By AnnaK in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-24-2010, 10:17 PM
  2. PH reading different from phenol red vs. strip
    By poolaris in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 12-18-2008, 12:54 AM
  3. ph test phenol red reads 7.2 then jumps to 7.5 !
    By maxhiller in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-11-2007, 12:42 PM
  4. pH indicator turns blue instead of redish?
    By Kilolab in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-01-2007, 06:12 PM
  5. salt level indicator
    By doriec in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-10-2006, 02:31 AM
