Ok, here's what I think is happening.
By my calculation (W.A.G.--Wild-A-bsurd Guess) you should have an FC somewhere in the range of 30 and a CYA around 20...roughly. You are nowhere near that.
You have between 13,000 and 13,500 gallons. 1 gal of bleach would add about 4.4 ppm of FC, and each pound of shock should add (roughly) 5ppm of FC and maybe 3 or 4 ppm of CYA
Hardness is very, very, VERY high.
I think either you have misread your test strips, which is VERY easy to do (For example: TC = FC + CC. If your FC is higher than your TC, you should be VERY suspicious--the TC tabs on strips are notoriously inaccurate).
Or...that algaecide with all its ammonia has used up all your chlorine.
Or both.
With new pool owners the best thing to do is keep it very, very simple.
Watch your pH, your FC and TC/CC (either), and your stabilizer levels.
Add Bleach to raise FC, Borax to raise pH, Muriatic Acid to lower pH, and CYA powder or liquid to raise CYA.
That's it. You can add a little polyquat, preferably just after you backwash.
You may want to take a sample to a pool store. They probably will get better results than you will until you get your K-2006.
