Thread: pH, what should it be? How long can I let it stay how low? Where should TA be?
    Jun 2011
    Default pH, what should it be? How long can I let it stay how low? Where should TA be?
    pH was 7.2 this morning, still 7.2 this evening... this is following water getting fairly low due to heat, extended backwash, and leaky multiport. How long do I let it stay there, and should I be concerned at all? I unfortunately have .5 copper in the pool, so I don't want pH to drift too high.
    TA is running around 110, where should it be, and how high do I let it go before I worry?
    I would add a little Borax because I'd like to get the borates in there, but it looks like lowering alkalinity is no fun, especially since I have no jets that point toward the surface, waterfallls, etc.
    Largo, Florida
    Default Re: pH, what should it be? How long can I let it stay how low? Where should TA be?
    I believe in most pools 7.2-7.8 is the ideal range. TA 60-130 (although I've seen others post much tighter ranges around the same median). http://www.poolsolutions.com/gd/pool...try-guide.html
  1. PH won't go/stay up
    By GAPool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-25-2013, 12:40 PM
  2. Pool heater won't stay lit!
    By Rob311 in forum Pool Equipment & Operations
    Last Post: 05-26-2012, 09:38 PM
  3. Heater Pilot Won't Stay Lit
    By hayshaker170 in forum Pool Equipment & Operations
    Last Post: 06-28-2011, 02:29 PM
  4. pH levels -- they won't stay down
    By kmmlangston in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-15-2010, 06:26 PM
  5. I BBBed my hot tub , but it won't stay
    By keithw in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-25-2006, 04:06 AM
