I believe in most pools 7.2-7.8 is the ideal range. TA 60-130 (although I've seen others post much tighter ranges around the same median). http://www.poolsolutions.com/gd/pool...try-guide.html
Kelemvor is correct. Anywhere between 7.2-7.8 is fine. Also, your alk is ok at 110.
