Thread: ABG Pad Help - 18' ProSeries Metal Frame
    Jun 2011
    Default ABG Pad Help - 18' ProSeries Metal Frame
    We've purchased an 18' x 48" ProSeries metal frame pool (similar to Intex) and have leveled the site at which the pool will reside. This was done so with a tractor/bucket which left shallow grooves from the teeth on the bucket. I'm looking for any and all suggestions on what our next step should be to prep the ground for the pool installation. Prefereably cheap! We aren't looking for long term (as in yrs) because we plan to sell and move within in the next year...therefore, we're hoping to not have to spend too much money (none at all would be nice but a dream none the less, I'm sure). Pavers (to place below feet) are on our list of things we need. Thanks!
    Default Re: ABG Pad Help - 18' ProSeries Metal Frame
    Normally, sand alone isn't a good idea -- it can wash out too easily. But it would probably work OK for a year, just to fill in between excavator tooth grooves.
  1. Drain12 ft. Metal Frame Pool
    By TheKs in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-20-2012, 07:57 AM
  2. Welcome from New York - Metal Frame 15 x 48 Set up issues.
    By Bill1404 in forum Intex-type Pool Setup & Operations
    Last Post: 05-26-2012, 12:32 AM
  3. Inflatable vs. Metal Frame
    By Styx555 in forum Above-Ground Pool Construction & Repair
    Last Post: 08-16-2006, 12:41 PM
  4. NEW 18' metal frame easy set agp questions.
    By darenjones in forum Above-Ground Pool Construction & Repair
    Last Post: 06-03-2006, 04:46 PM
  5. Intex Metal Frame Pool
    By SBaker in forum Above-Ground Pool Construction & Repair
    Last Post: 06-01-2006, 11:48 AM
