Thread: help with and old sand filter
    Jun 2011
    Default help with and old sand filter
    I have a older hayward gm 140 4 port sand filter and I need to know how to connect it to my pump and pool there isn't
    and arrows or markings on the filter so im lost on how to hook it up , please help if you have any ideas thanks.
    Default Re: help with and old sand filter
    Hi Chris and welcome to the Pool Forum! Once your registration is complete and your post is moved out into the classified sections of the forum, some of out equipment gurus can give you a hand with this.
    You'll need to take pictures, and send them to poolforum AT gmail DOT com.
    Trying to help with old equipment is hard, without knowing exactly what you have.
    PoolDoc
  1. How often shoud I replace sand in sand filter?
    By mikef in forum Pool Equipment & Operations
    Last Post: 07-18-2011, 11:41 PM
  2. Sand Filter Sand amount question
    By kevincad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2008, 09:36 AM
  3. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
  4. Sand in bottom of pool from sand filter
    Last Post: 06-20-2006, 01:01 PM
  5. Jacuzzi ST-24 sand filter - sand in pool
    By ksturge in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 09:58 AM
