Results 11 to 15 of 15
Thread: New Pool Owner. Help!
    Jun 2011
    Southern Minnesota
    Default Re: New Pool Owner. Help!
    So i tested the FC and CC and i got this
    FC- 4.6
    CC- 0.4
    For FC it is 0.2 X 23 drops = 4.6 so that number needs to be 25?
    this is why i paid for lifetime membership. Lol...Lewis
    Steel Sided Pool/Vinyl Liner -- 26k gal
    PentAir Clean N Clear Plus Filter -- PentAir UltraFlow Pump
    Yep. You got it. It needs to be taken up to 25ppm. By the way, just use the 10ml sample for your tests. It will give you within 0.5ppm accuracy which is plenty good enough and it will make your reagents last longer.
    Jun 2011
    Southern Minnesota
    Thank you. Will bringing that up to 25 help with the stains in the liner? Last fall we paid the pool co over 400.00 to close pool and 300.00 to open this spring and i was not here in the fall and they did not clean it. I spent days dragging out leaves, bugs, and unidentified things out of the pool which i believe left stains. This pool was beautiful until they closed it.
    Vinyl pool? Forget calcium! Don't bother testing it again unless you are adding calcium (a waste of money) or Cal-Hypo--a chlorine chem that adds calcium.
  1. New Pool Owner
    By HMSpool in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-20-2012, 10:32 PM
  2. New pool owner
    By Ameztoy in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 02-27-2012, 09:06 PM
  3. New Pool Owner!
    By Kainoa in forum Pool Equipment & Operations
    Last Post: 11-13-2011, 09:35 PM
  4. new home owner -- new pool owner -- clear as MUD
    By Andyman33 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-06-2011, 07:51 PM
  5. New Pool Owner
    By bobcat in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-25-2010, 03:03 PM
