Thread: Adding liquid chlorine
    Jun 2011
    London, Ontario, Canada
    Default Adding liquid chlorine
    I have a 21' above ground, round pool and I use mainly chlorine pucks in a floating dispenser. Once a week or so, I add a liter or two of liquid chlorine from a 10L container. I add the chlorine to half a pail of water and toss it over the pool water (I hang on to the pail!). No matter how carefully I do this, a few drops of chlorine always manage to land on my shirt or shorts. Lately, I have removed my shirt and used a plastic garbage bag as a "HAZMAT" suit over my shorts. But this is a bit of a pain to put on, not to mention unattractive. Does anyone have any suggestions how I might disperse the chlorine in a better way, without buying an automatic dispenser that connects to the plumbing?
    Default Re: Adding liquid chlorine
    I always just pour my liquid chlorine (bleach) directly into the skimmer while the pump is running. I pour very slowly so it doesn't splash. There is no need to pre-mix liquid chlorine into a pail of water.
    Welcome to the Pool Forum!
    I put mine slowly into the the return stream in the deep end, and let that help disperse the bleach. If you take your time, there's no splashing involved.
    drband's Avatar
    drband is offline Lifetime Member Thread Analyst drband 0
    Gainesville, GA
    Ditto both above. I just replaced my liner and I noted that the manufacturer of the new liner recommends adding chlorine through the skimmer. Definitely do one or the other of the listed options here. Sorry about your clothes!
    10,000 gallon IG vinyl liner pool, BBB user, salt added to 2300 ppm (because it makes the water feel great!), new liner/new water on 6/23/11, algae-free since 2006 (at least that's as far back as I remember). 1HP Hayward 2-SPEED CONVERTED Superpump, Hayward sand filter, PS234 test kit.
    Goal: To remain completely algae-free for the life of this new liner!
    Life lesson: It is what it is.
    12'x24' oval 9K gal IG pool; bleach; Hayward 244T sand filter; Hayward Super pump, 1 HP, 2-speed pump; 24hrs on low speedhrs; PS234; utility water; summer: ; winter: ; android phone; PF:13
  1. Liquid Chlorine?
    By proximo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-01-2013, 11:48 AM
  2. liquid chlorine
    By mrs.rainbow in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2011, 10:24 AM
  3. How / Where Do I buy Liquid Chlorine?
    By cheshamjim in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-29-2007, 05:06 PM
  4. Liquid shock, bleach, liquid chlorine?
    By rollinrock in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2007, 01:26 PM
  5. Liquid Chlorine Feeders
    By Sprint54 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-07-2007, 06:16 PM
