Results 1 to 10 of 17
Thread: Amato Inc. test kit refills
    Default Re: Amato Inc. test kit refills
    is this not the page you get when you click on the link in my signature?
    http://poolsolutions.com/testkit-order-links.html
    And, then from their, the next page should show you some kits and if you click on the name of the kit, it should take you to an Amazon page. Is that not what you are getting?
    Lehigh Valley, PA
    No. The links on the Pool Solutions page all go directly to Taylor Technologies.
    That has to be something Amazon did; the URLs on the Poolsolutions page are hard-coded to Amazon.
    I'm seeing Amazon now, too. Can you check again?
    Jun 2011
    Northern VA
    Watermom, the link in your sig. does take me to the pool solutions page with all the different kit information but the only links on the Pool solutions page is the name Taylor Tech. under the kit info. The actual names of the kits are not links.
    27 ft x 52 in AGP
    Hayward Power flo LS 1.5 hp - Hayward model s180t sand filter
    27' round 17.2K gal AG pool; hand fed; Hayward model s180t sand filter sand filter; Hayward Power flo LS 1.5 hp pump; 24/7hrs; Taylor Complete FAS-DPD Pool Water Test Kit K-2006; orig. truck but use well to resupply; summer: ; winter: ; ; PF:7
    I see what's happening.
    The "Taylor Tech" link goes to Taylor, as intended. I assumed it would be obvious to others (since it was to me -- dumb, I know) that this was an info-only link, and that the purchase was via the Amazon photo related links.
    I'll be working on that page next week, and will make it clearer.
    I'm assuming that if you click the link in the Amazon box, it goes to Amazon?
    Jun 2011
    Northern VA
    OK, I know what the problem is now. I don't see the amazon box because I use Mozilla Firefox as my browser (as do many people). Ads are blocked so I need to allow them on this site in order to see them, which I just did and now I see the pictures and the links work perfectly. Had I seen them originally it certainly would have made sense. Maybe you could add a message to Firefox users to disable their adblock for this website.
    Thanks, now I can order through the Pool Forum!!
    27 ft x 52 in AGP
