Results 1 to 10 of 17
Thread: Where to start? BBB pool!! HELP!
    Default Re: Where to start? BBB pool!! HELP!
    'Bear, I think Holly got the point.
    In fact, our B-B-B method is based on the fact that good pool maintenance does NOT need lots of chemicals pushed by pool stores. We generally don't recommend:
    Phosphate removers
    Clarifiers
    Bluing
    Flocculents
    Yellow-Out
    Metal "removers"
    Copper
    Silver
    Nor a zillion other things.
    Normal pool maintenace, and even algae fighting can almost always be done with:
    Bleach/Liquid Chlorine
    20 Mule Team Borax
    Muriatic Acid
    Baking Soda
    Washing Soda
    and CYA(stabilizer).
    Jun 2011
    Michigan
    Not a fear Monger here. Just cautious is all Can't wait to get this pool up and running!! Any suggestions on the best way to put in a new overlap expandable liner?
    Holly,
    Post that question in the above ground pool forum where you're likely to get some of the installers to see it. Some of them don't read the chemistry threads.
  1. Sand filter changed @ start of season ? HIGH PRESSURE @24 PSI FROM START
    By timmygreene in forum Pool Equipment & Operations
    Last Post: 05-21-2010, 07:48 AM
  2. New pool start up
    By micon2 in forum DPD-FAS based testing
    Last Post: 10-20-2006, 11:54 PM
  3. Pool Start Up
    By micon2 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-07-2006, 10:52 AM
  4. Pool start up?
    By Trimom in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 11:04 PM
  5. New AG pool-How To Start???
    By rferrel1 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-22-2006, 07:19 PM
