Go ahead and get some chlorine so you can immediately get some chlorine in to the pool. Cal-hypo would be a good choice to start with as it will add some calcium at the same time as chlorine. Calcium hardness between 200-400 is the target. Then, you should switch to some forum of liquid chlorine. For this large of a pool, if you can find some 10 or 12.5% liquid chlorine (sodium hypochlorite) that would be more convenient for you than bleach which is 6% sodium hypochlorite.
You will also need to raise your alk. Get some baking soda. You may be able to buy a larger bag at Walmart or Sam's. It will take approximately 6 lbs. to raise it by 10ppm. Aim for 80-120. I would NOT suggest adding a huge dose all at once or you may have cloudy water issues. Add 5 or 6 lbs. at a time. It can be added slowly to the skimmer while the pump is running.
BTW, tap water does not have CYA in it, so your reading of 20 is inaccurate. You will need about 15 lbs. to get to a reading of 40ppm.
Good luck. Repost if you have further questions.
