Results 1 to 10 of 14
Thread: pump running 24/7 or what?
    May 2011
    kentucky
    Cool pump running 24/7 or what?
    I have very clear water, but I also run pump 24/7 should I do that, or should I for pump sake put it on a timer as so it don't run all time or should they ? I have a 2 speed pump and its on low 24/7 should I keep it that way?
    Scottsdale, Arizona
    Default Re: pump running 24/7 or what?
    If you have a well balanced pool and no algae issues I see no reason to run it 24 hours a day . I only run mine for 6-8 hours depending on the time of year. That is long enough to produce the chlorine I need and turn the water over multiple times. I also run mine at night due to lower electric rates.
    May 2010
    Asheboro, NC
    Quote Originally Posted by airraid1999 View Post
    I run mine 24/7 365 days a year. I have a dual speed super pump, 1 hp/1/6th hp on a 16' x 32' inground pool. The 30 year old motor was just in the shop for the third time. It needed bearings again. Ever notice when a light bulb pops? Usually when you turn the thing on. If you have crystal clear water as I do by running 24/7 on low, why mess with a good thing? Bearings every 10 years, no problems with on off surges, minimal electric use and pristine water.
    If it aint broke, don't fix it.
    Actually, you'll probably get a longer life if you run it long enough to turn your water over twice a day and no more. Plus, had you been doing that all these years you would have saved enough in electricity to replace the pump several times over.
    Scottsdale, Arizona
    wow.. 24/7 365 ?
    why?
    May 2011
    kentucky
    i live in ky so its not 365 just about 3 1/2 months of swimming
    You can save yourself some money on your electric bill. Run the pump for about 8-10 hours per day split into two sessions. That will be sufficient and be cheaper. The exception to this is if you are fighting algae or have cloudy water that you are trying to clear up. In those cases, we recommend running the pump 24/7, but other times, not necessary.
    Jun 2011
    Franklin, TN
    You might want to do a couple of runs each day, each 4 or 5 hours at a time.
    I just got my first electric bill after a full month of running the pump 24/7. Yikes! Now that my water's clear I'd love to cut back on that.
    How can you work in a schedule like this around a normal workday? I'm gone for 10-12 hours a day during the week.
    Also, seems like daytime would be more crucial than nite to keep the water circulating, would that be true? Is one more important than the other?
    You can use a timer set for one of your runs -- maybe during the day while you are not home. Then, in the evening, you can manually turn it on for the other run. Or, have two timers. Do they make a timer that can have two on and off periods? They might but I don't know about that.
    It doesn't really matter all that much when your circulate as long as you circulate for at least an hour after adding bleach, etc.
  1. Cost of running a pump 24/7
    By Guppy in forum Pool Equipment & Operations
    Last Post: 05-31-2012, 08:37 PM
  2. whisperflo pump running hot
    By klewando in forum Pool Equipment & Operations
    Last Post: 07-14-2011, 11:29 AM
  3. Running pump at night?
    By Cold Drink in forum Pool Equipment & Operations
    Last Post: 08-07-2007, 07:59 PM
  4. running pump
    By nicker in forum Above-Ground Pool Construction & Repair
    Last Post: 07-28-2006, 07:57 PM
  5. Hayward pump running hot
    By chipholder in forum Pool Equipment & Operations
    Last Post: 06-09-2006, 12:02 PM
