Closed Thread
Results 1 to 9 of 9
Thread: Chlorine tablets to clean toilet??
    Hoskins, Nebraska
    Default Re: Chlorine tablets to clean toilet??
    Thanks, before I order any Kaboom refills online - I wanted to see if anyone from the forum would know how the chlorine tablets for pools would work in this situation?? The Kabooms work ok- not nearly as good as the Puricle tablets they replaced, but better than anything else I can purchase that I've found. Just thought I'd check on the pool chlorine tablets idea first. Thanks!
    Sincerely,
    Donya (huskerfan)
    "2000 Flushes" used to sell a chlorine version that didn't turn the water blue. Every 3-4 months it destroyed the flapper valve and the cistern would leak into the commode and then fill up again.
    Seems to me that this was all discussed here on the forum a few years ago. Use the search feature in my signature and you might find some old threads that you could read.
    Hoskins, Nebraska
    Thank you - haven't lurked at the forum for quite a while so appreciate the reminder about searching . I think I'll pass to be safe and order more kaboom tablets online, thanks!
    Sincerely,
    Donya (huskerfan)
    Honesdale PA
    Is there a reason they're called KABOOM ?
Closed Thread
