Thread: Recommend a heavy duty hose...
    steveinaz is offline Lifetime Member Weir Watcher steveinaz 2 stars steveinaz 2 stars
    Southern Arizona
    Default Re: Recommend a heavy duty hose...
    Hey Lisa! Good to hear from you.
    They make angled hose plates for skimmers. That way you don't have to bend the hose to plug it into the skimmer socket. Less likely to collapse.
    Southern Arizona
    The hose collapses right at the coupling--the suction is just too great. I did find a "commercial grade" heavy duty hose at Doheny's pool supply. 40 footer was $65. I'll let you all know if it works once it arrives.
    Southern Arizona
    EUREKA!
    Found a hose heavy duty enough to not collapse while vacuuming from the skimmer port. Who knows who the manufacturer is, but I got it at Doheny's Pool. It's got a 5yr warranty. Nice and stiff, no problems; no need for a vac plate or any other non-sense.
