Results 1 to 10 of 10
Thread: New Pool - Chemical Start-Up
    Jun 2011
    Default Re: New Pool - Chemical Start-Up
    I'll get some more bleach and do what you suggest. After I added the full gallon the other day, I checked an hour after and still had FC of 0. That could be my test strips though.
    I just read another post below mine that indicated FC being affected by algae growth... I know I have clear water now, but I suppose it could be forming.
    At this point, is it more cost effective to use bleach, or should I go for some other commercial chlorine product? I am afraid that I am limited to what Wal-mart sells until Friday.
    I'll just keep adding bleach for now. Thanks for the help. I get it tested by the store this weekend and get back to you.
    Intex Above-Ground Swimming Pool, Ultra Metal-Frame, 24' x 52"
    About 14,600 gallons?
    Intex 2,500-gallon filter pump
    Jun 2011
    Okay, you guys are super. Thanks for all your help. I went to the pool store again last night to get the cya tested and found that my test strips just don't work right. My new readings are:
    fac: 3
    tac: 3
    pH: 7.6
    ta: 100
    cya: 40
    calcium hardness: 150
    tds: 300
    phosphates: 0
    So, I am guessing that everything is good. Looks good. If you have any advice, I'd love to hear it. Thanks again!
    Test strips NEVER work right, except as sort of "Is there some, or is there none?" guess-strips.
    Order a K2006 -- link below, make sure Amazon 'seller' is Amato Ind; some others have shipped K2005's; K2006C costs 35% more, but has 3x as many tests.
    Other than that, your readings look good. Just maintain that, and you should be fine. Do remember to monitor your CYA, and adjust your chlorine levels up as your CYA goes up. (See Best Guess page in my signature for "how-to").
